Dukerc51
Ok, please find attached photos from my mill. The 150 node connects to the common side of most of the input modules on the PLC as shown on page two of the drawing. This is physically in many spots as they are all connected together electrically.
Attachment 292950
This is the PLC in my mill. Note the two locations that the 150 labelled wires attach. If you trace the other wire attached here you will see that all the commons on the input modules are connected together as shown on page two of the drawing.
Attachment 292952
Close up of top left location.
Attachment 292954
Close up of top right location.
I don't know which connection is at the other end of the wire you are showing. If it is the connection from the spindle speed control card then none of spindle/coolant/brake switches will work until it is connected. There may also be other things wrong or broken. Check the 28VDC power supply on the spindle speed control terminals, anything between about 24VDC and 30VDC should work. Oh, and my PLC is modified to work with my VFDs and Mister, that is why I have an AC module in the one location different from yours.
John
