586,076 active members*
4,119 visitors online*
    May 2014
    Problem saving files
    Currently getting this message when exiting Solidcam: "Operation compressing failed. Original CAM-Part and SolidCAM temporary folder content will be kept." Hence, any changes I make are not actually getting saved in the intended folder.
    I was originally using the 32 bit version, then switched to the 64 bit version of Solidcam 2014 SP1. Could that be the problem?
    Does anyone know what the problem can be?
    Oct 2013
    153
    Re: Problem saving files
    Never had that error message ! You can give a try by putting the compression ratio to '0' in solid cam settings
    May 2014
    Tried it, didn't work. I might have to start from the beginning if I can't find out what's going wrong.
    Oct 2013
    84
    Quote Originally Posted by rss27 View Post
    I just upgraded to a mobile desktop laptop and installed the 2015 SP03 HF3 and I'm getting the same error. I brought the compress level to "0" and that didn't work. If I uncheck the box for create new parts to compressed mode and close cam-part..convert non-compressed to compressed mode the error dissapear, but I now have folders with multiple parts. Anyone figure this out or experience this before, I didn't have a problem on my old workstation both are Win7 pro 64bit.?
  1. default setting for saving files?
    By The Wolf! in forum OneCNC
    Last Post: 10-31-2013, 06:14 PM
  2. Saving back mc files
    By dtm in forum Mastercam
    Last Post: 08-16-2011, 01:22 AM
  3. Garbled Curves when saving SW2009 Drawings as DWG files
    By KevinWilkins in forum Solidworks
    Last Post: 04-13-2010, 05:06 PM
  4. Saving program files
    By Troy Kingan in forum Hardinge Lathes
    Last Post: 10-22-2008, 04:35 PM
  5. saving files with a DWG or DXF
    By casta-baga in forum Mastercam
    Last Post: 08-07-2008, 04:02 AM
