586,493 active members*
2,502 visitors online*
IndustryArena Forum > CAM Software > EnRoute > Spindle won't start spinning on Multicam
    Sep 2015
    This wasn't a problem last week, and I installed Enroute 5 on a new computer and added all the same machine drivers and everything, but now when I start a job, the spindle won't start. Any ideas?
    Oct 2007
    18
    Quote Originally Posted by lettersetc View Post
    If it was working before the install, i would check the gcode for the S parameter (SPINDLE SPEED), as well as the M parameter to turn it on (M19,20 CLOCKWISE,COUNTER CLOCKWISE,ETC)
    Sep 2015
    Re: Spindle won't start spinning on Multicam
    So here is some GCode from a job, I don't see an M19, M20.
    M90
    G90
    G70
    G75
    G97 S18000
    G00 CTCInsert 3/16" End Mill
    G00 X20.191 Y3.1531 Z-0.5
    M12
    G01 X20.191 Y3.1531 Z0.473 F15.0
    G01 X20.191 Y4.3234 Z0.473 F150.0
    G02 X20.2414 Y4.6455 I21.0786 J4.3494
    G02 X20.312 Y4.7617 I20.5911 J4.5124
    G02 X20.5147 Y4.8709 I20.5852 J4.4975
    G02 X20.7046 Y4.8904 I20.6935 J4.0619
    G01 X21.5015 Y4.8904 Z0.473
    G02 X21.7538 Y4.8694 I21.5297 J3.7024
    G02 X21.7778 Y4.8631 I21.6807 J4.5458
    G02 X21.9194 Y4.7662 I21.6831 J4.5727
    G02 X21.9915 Y4.6538 I21.5867 J4.4734
    G02 X21.9976 Y4.6351 I21.868 J4.6034
    G02 X22.0067 Y4.5588 I21.492 J4.5359
    G02 X22.0132 Y4.2918 I17.8685 J4.3243
    G01 X22.0132 Y2.1249 Z0.473
    G02 X21.9705 Y1.7253 I20.4854 J2.0863
    G02 X21.9059 Y1.5854 I21.5748 J1.8231
    G01 X21.9012 Y1.5796 Z0.473
    G02 X21.7688 Y1.4953 I21.6805 J1.7799
    G02 X21.4582 Y1.4531
    Jun 2010
    463
    Which machine are you using and which driver did you choose in the set-up
  1. multicam Sf not start
    By martin-g3 in forum Multicam Machines
    Last Post: 06-25-2015, 03:10 AM
  2. multicam Sf not start
    By martin-g3 in forum BobCad-Cam
    Last Post: 06-23-2015, 11:05 AM
  3. X6-1500GT - Spindle not spinning
    By Demanth in forum Chinese Machines
    Last Post: 11-22-2014, 05:11 PM
  4. Spindle spinning in reverse
    By SwampDonkey in forum Tormach Personal CNC Mill
    Last Post: 09-29-2014, 02:39 AM
  5. How many rpm's is this spindle spinning?
    By Apples in forum Uncategorised MetalWorking Machines
    Last Post: 03-14-2008, 08:40 PM
