Mitutoyo 543-558A LCD Digimatic Indicator 0-2in 0-50.8mm Travel
This is a brand new, never used Mitutoyo 543-558A Digital indicator. It was bought several years ago for my shop, but sat in the gauging cabinet unused. 0-2in 0-50.8mm Travel. Time to sell it. This is currently selling for $750-$800 right now.
FEATURES
With the ABSOLUTE Linear Encoder technology, once the measurement reference point has been preset it will not be lost when the power is turned on.
GO/?NG judgment is performed by setting the upper and lower tolerances. If a judgment result is out of tolerance, the display backlighting changes from green to red, so tolerance judgment can be made at a glance.
An analog bar indicator has been integrated to handle upper/lower limit approaching and zero approaching. It enhances the ease of operation in the same manner as a dial indicator. The display range of the analog bar can be changed.
With SPC data output.
Technical Data
Accuracy: Refer to the list of specifications.
Resolution: 0.01mm/0.001mm or .00005?/.0001?/.0005?/.001?/0.001mm/0.01mm
Display: LCD
Length standard: ABSOLUTE electrostatic capacitance type linear encoder
Max. response speed: Unlimited
Measuring force: 1.8N/2.3N* or less (*50mm range models)
Power supply: 9V DC (via AC adaptor)
Function
Origin-set/Preset, Zeroset, GO/?NG judgment, Max/Min value
hold, Runout measurement, Resolution switching, Counting
direction switching, Power ON/OFF, Data output,
inch/mm conversion (on inch/metric models only)
Alarm: Low voltage, Counting value composition error,
Over-flow error, Tolerance limit setting error
List Date: 5/31/2015
For more info, click here to view the original listing: Mitutoyo 543-558A LCD Digimatic Indicator 0-2in 0-50.8mm Travel
This item is no longer available.
Mobile friendly version: Mitutoyo 543-558A LCD Digimatic Indicator 0-2in 0-50.8mm Travel
Go Mobile: Download the free Panjo iOS app now!
