586,060 active members*
4,152 visitors online*
    Jun 2015
    4
    Exclamation Mazak AJV18 - M19 wrong orientation
    hi guys.
    i have a mazak M32A - ajv18 machine.
    after hard reset - some parameters has lost ot not up to date.
    i have a problem with tool changer. when we run M19 command we are getting wrong angle and the spindle hits the atc ARM.
    IT SEEMS THAT the M19 has wrong orientation , - and need to change in 90 degree more to get into the arm.
    any ideas? please see images, where is the orientation parameter code?
    thanks for the help.
    Jun 2015
    4
    Any Ideas?
    please make a suggestions.
    thanks!
    Re: Mazak AJV18 - M19 wrong orientation
    Quote Originally Posted by avicohen View Post
    Any Ideas?
    thanks!
    Try parameter J 87, it is spindle orientation. Increase or decrease the value, and do a tool change cycle with to much care. One unit it is one degree.
    Hi I have a mazak ajv,18
    I have lost all parameters. Now it's OK but still missing. Macros of the probe
    Can u help me?
    Enviado do meu EML-L29 através do Tapatalk
  1. Replies: 4
    Last Post: 12-26-2023, 06:54 PM
  2. Replies: 3
    Last Post: 07-19-2017, 09:16 AM
  3. CNC X, Y, and Z Orientation
    By Nitwit in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 07-18-2012, 10:30 PM
  4. ORIENTATION
    By dcutler35 in forum GibbsCAM
    Last Post: 06-13-2012, 12:40 AM
  5. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
