Does anyone here have the g-code to finish an 80% lower with the Novakon Pro?
ram48
Sorry, don't understand the question. Elaborate!
John
Lower receiver on an AR15 rifle.
Why start with an 80% lower when you can just start with a block of aluminum?
These are the 3D Models, not g-code (assuming you have CAD/CAM you can generate the g-code yourself):
CNCGUNSMITHING - www.cncguns.com - Downloads
Tim
Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
Good point I use Bob-cad cam so it should work.
Have you used that download?
no, but it would be a good project, thinking about it.
Tim
RifleConnection.com has a download of the Gcode that should work for you. Check them out, I have purchased a few blueprints and the CNC code that worked great on my haas, even came with a tool list and locations where to touch off on. Id recommend them, they are doing awesome things for us guys who build at home.
