586,082 active members*
3,703 visitors online*
Results 1 to 11 of 11
    May 2011
    92
    Question Feeds and Speeds DOC Gcode
    Still new at this. Done some slotting and holes in aluminum plate. Some drilling using the rotary.
    Had a problem today, where the piece got so hot it expanded between the rotary's 6jaw chuck and the dead center tailstock.
    After about the 5th linear slot, the rotary skipped steps, I guess the strain against the rotary was too much. End of job, in the trash.
    Do these X feeds and Z DOC look correct ? Mill is turning at 1700rpm.
    It seemed to cut well w/ nice chips. Hand spraying WD40. There is no coolant spray on this machine.
    Heres my handwritten gcode using Mach3. Spindle is manually turned on. 6061T6 aluminum round.
    % 1st Side 3/8 mill 2F DOC.570 2.00Dia 7slot
    G90 G20
    G0 Z0.100
    G91 A-51.434 (Rotary)
    G90 X0 Y-0.368
    M0 (Spindle on)
    Z-0.200 F2
    G01 X-12.13 F10
    G91 G01 Z-0.130 F2
    X12.13 F10
    Z-0.130 F2
    X-12.13 F10
    Z-0.110 F2
    X12.13 F10
    G90 G01 Z0.100 X0
    M30
    Nov 2009
    4415
    Re: Feeds and Speeds DOC Gcode
    Am I reading that right? Are you doing cuts at -.110"-.130" at a feedrate of 10ipm? If so it seems reasonable. Especially for slotting.
    A lazy man does it twice.
    May 2011
    92
    The calculators call for 10.2
    But I had a heck of time finding what the DOC should be for a 3/8 2F.
    1/2 the diameter of the bit. But seemed alittle heavy.
    (the first cut at Line #6, .200" DOC, is actually off the side of the round, more like a .150 DOC.)
    About 30mins, the part sure does get hot. Find a way to cool this down.
    Dec 2013
    158
    Air works great to keep things cool.
    May 2011
    92
    Quote Originally Posted by rs4race View Post
    My compressor is a wee 12gal 110v. Constantly running will trip the breaker along w/ the mill.
    Maybe a CO2 tank ?
    Dec 2013
    158
    My little compressor runs quite a bit too. I had recently thought about trying a low pressure air pump. The type used to pump rafts and inflatables. I think you would get the airflow needed with a lot less noise and power consumption.
    May 2011
    92
    You have a cold air cooler tube ?
    Nov 2011
    205
    You probably have a good low pressures air source -- the output of a vacuum cleaner !!!
    Don
    Dec 2013
    158
    That doesnt sound like a bad idea. Use one side to suck up your chips and the other to blow air as coolant.
    Nov 2009
    4415
    I did this at 1 time on my little Dyna DM2400 (I am referring to using both the blow and suck of a vacuum cleaner). It worked ok. I used a panty hose stretched over the spindle and table enveloping the work area. That was cheap and eliminated any rogue chips.
    Another source of low pressure air is an old compressor from a refrigerator. They are usually readily available whenever you see a fridge being thrown away. They are almost dead silent. Not a lot of volume. I did rig one onto an old compressor tank. Takes a little time to fill but it does it silently and cost me little to nothing.
    Dont forget a simple hand pumped fertilizer sprayer. It is plastic, you pump it by hand, the nozzle is adjustable and would be easy to mount it that was the plan. If set to mist or fog it would last a considerable amount of time before needing to be pumped up again. If you are like me, standing and hovering over your machine while running a long code is boring. Pumping it up might break the monotony.
    Nov 2011
    205
    Quote Originally Posted by Fastest1 View Post
    A similiar item is a foot pump for a blow up boat. Hands Free !!!
    Don
  1. Feeds & Speeds
    By GTFreeFlyer in forum Momus Design CNC plans
    Last Post: 09-24-2012, 04:04 AM
  2. Need some help with speeds & feeds
    By ldkell_2000 in forum MetalWork Discussion
    Last Post: 03-01-2008, 05:35 PM
  3. speeds and feeds
    By rodzilla in forum Benchtop Machines
    Last Post: 02-20-2008, 05:30 AM
  4. feeds and speeds
    By porkchop21 in forum Bridgeport / Hardinge Mills
    Last Post: 08-31-2007, 01:52 AM
  5. feeds and speeds
    By rchprks in forum MetalWork Discussion
    Last Post: 07-18-2006, 12:48 AM
