I have a machine that is about 50% built using 80/20, 3060 gantry etc... Pretty beefy (to me).
the machine footprint is about 42x60 w/ a cutting area of about 30x48. The y axis (dual ballscrew) will have 60" ballscrews on each side. 20mm 5 or 10mm pitch.
Electronics are up in the air right now, I'm between a 4 axis g540 kit from cnc router parts and possibly up to a smoothstepper+gecko/leadshine combo. Maybe servo if I can find a 'cheaper' option.
Basically I want a machine that can do it all, I want to be able to machine aluminum. (yes I know this isn't a large machining center)
I also want to be able to machine foam/wood (3d) for casting or mold making (probably wont happen a ton!)
The majority of the work I actually do currently w/ my 1st machine is smaller aluminum engravings.
So my wants (whether they are unrealistic or not) need a balanced result to accommodate both. By wanting to do 3d work in softer materials, that typically warrants faster speeds, I'm sabotaging the fact that I want to also do aluminum, typically lower speed requiring greater torque.
I have ran through countless threads discussing the pros and cons of 5mm vs 10mm pitch screws. Part of me says 10mm would be best, but the epic part of me wants the sub .005" resolution
With a ballscrew critical speed of about 1200rpm the best i could hope for out of 5mm pitch would be ~200ipm rapids and double that for a 10mm pitch. If 700+ rpm on a stepper system is easily attainable, I lean towards a 5mm pitch system for the torque and resolution advantages
What is your take on this predicament, I think I've made up my mind, but like to hear others thoughts (the decision is maddening).
