586,102 active members*
2,573 visitors online*
Results 1 to 16 of 16
    Mar 2006
    21
    Mystery DC servo drive
    I inherited a DIY machine running Mach3 with DC servos.
    I got only hardware so I have to re-configure the software.
    It came with servo drives I've never seen before.
    The system builder is sick and unavailable.
    After a couple hours sprelunking the web, I still can't find
    anything on them.
    I'm hoping someone out there might recognize them.
    Here's the only ID they have.
    Any help is appreciated.
    Attachment 293746
    Jan 2007
    599
    Re: Mystery DC servo drive
    i'd post a pic of the whole board as well.
    Mar 2006
    21
    Thanks for your interest.
    This is it.
    Rich
    Attachment 293868
    Apr 2004
    733
    That logo is Fastprint. It's a printed circuit board manufacturer in China. They probably got contracted out to design and layout the printed circuit board for some OEM.
    Unless there is another company name on the underside of the board of the actual designer, it's going to be difficult on finding any docs.
    The logo of the encoder disk is probably the designer but I've never seen that before.
    Jan 2007
    599
    That or they could be some DIY design that float around here every once in a while, like JFong said check the back of the board, if nothing there its going to be tough. Im guessing the servo tuning on the board is already done. should not be to hard to find the steps per inch even by trial and error. Then start with medium speeds and low accel decel settings in mach and go from there. Other than that i'd check how good they look in the garbage can....
    Apr 2004
    733
    Also to add the terminals L1 L2 L3 leads me to believe it's a brushless driver. I thought I knew most of the motor driver manufacturers but that square logo of the encoder disk is something I've haven't seen before. I've checked a recent database of several hundred motor manufacturers and no logo similar to that came up.
    Mar 2006
    21
    It truly is a mystery.
    Best Regards
    Oct 2012
    342
    Edited out.
    Mar 2006
    21
    They were connected to DC brushed servos. They also lack labels but their form factor closely matches DC brushed servos sold by Keling. Based on the condition of the wasteboard, the machine was operational.
    Thanks for your input.
    Best
    Rich
    Oct 2012
    342
    Quote Originally Posted by Exhibitology View Post
    Best
    Rich
    Can you post some pictures of the motors and maybe something more than just the board of the drive? Maybe one of the drive a bit farther back with the cables connected?
    -Dan
    Apr 2004
    733
    Best
    Rich
    Most brushless drivers can also run brushed motors too. Take a look at all the leadshine servo drives. See if the connector inputs match to your drive. Just a hunch since a lot of kieling motors were sold with leadshine drives. Some of the older leadshine were cloned by 3rd party and sold on eBay. It may not have leadshine name on it which may be the case here.
    Apr 2004
    733
    Also send a inside/outside image of the entire controller box showing the drives and wiring.
    Mar 2006
    21
    I'm in the process of rewiring his control box. I'll send photos when it's presentable.
    Rich
    Oct 2006
    323
    The company logo and drive looks to me might be a Granite Devices servo drive, (see granitedevices.com)
    Mar 2006
    21
    You nailed it.
    It is a Granite Devices VSD-A.
    Excellent.
    Thank You.
    Rich
Name:	Screen Shot 2015-09-30 at 4.30.40 PM.png
    Apr 2004
    733
    Nice, the brushless driver specs looks to be really good. Better than the Applied Motion drives I have.
  1. MISSING AC SPINDLE DRIVE + 3 AXIS SERVO DRIVE
    By Affaq999 in forum Vertical Mill, Lathe Project Log
    Last Post: 02-20-2015, 03:50 AM
  2. Servo Drive Selection Dugong vs. Gecko drive
    By native34 in forum Servo Motors / Drives
    Last Post: 02-06-2015, 04:37 AM
  3. Replies: 0
    Last Post: 01-20-2015, 01:28 AM
  4. Replies: 0
    Last Post: 05-24-2014, 02:23 PM
  5. CNC Lathe - Servo direct drive or pulley drive?
    By s76tools in forum Uncategorised MetalWorking Machines
    Last Post: 09-06-2009, 05:17 PM
