Hi all, been away for quite awhile, but am getting back into cnc, and have always found you guys to be most helpful.
I just got a new router off of Ebay from Globalfreeshipping. It arrived in good condition, and only took an hour or two to get running. What I do not know, is that it would seem to me that the spindle should also be controlled by Mach3, not just the knob on the VFD. My spindle will not turn on with Mach3. I did not install the version of Mach3 that came on the disk with the mill, I already had a licensed version so I chose to use that. Does anyone have any experience with this machine that could walk me thru a few things.
This control box is a parallel port version with the VFD built into the box.
I hope someone can help.
Thanks in advance!!!!
Walt
