586,117 active members*
3,510 visitors online*
    Aug 2013
    32
    Exclamation HELP MACH3 VBSCRIPT
    helllo
    if you could help me with my problem that would be great .. i have a little problem with mach3 vb script .. whenever i write this vb script it sends a message says "syntax error" is there anything wrong in the script ... im a newbie here ( the script is for Mach3 probe that works with THC proma ) and if you have good probe scripts that works with THC that would be great if you sent them
    the script:
    CurrentFeed = GetOemDRO(818)
    PierceHight = -4.0
    ProbeFeed = 1300.0
    Code "G90 F" &ProbeFeed
    If GetOemLed(825)=0 Then
    Code "G31 Z-117 F" &ProbeFeed
    While IsMoving()
    Wend
    Code "G4 P0.25"
    ZprobePos = GetVar(2002)
    Message "ProbePos is" & ZprobePos
    Code "G0 Z" &ZprobePos
    While IsMoving()
    Wend
    Call SetDRO(2. PierceHight)
    While IsMoving()
    Wend
    Code "G4 P0.6"
    Code "G0 Z 0"
    Code "G92 Z0.0"
    Message "Z at Perice Hight " & ZprobePos
    Code "F" & CurrentFeed
    StartTHC()
    ZeroTHC()
    Else
    Code "(ERROR. Plate is Grounded)"
    GotoSafeZ()
    Exit Sub
    End If
    if you could help me please reply soon
    Jul 2003
    1220
    Re: HELP MACH3 VBSCRIPT
    You should have a space between the & and variables.
  1. need to convert conventional gcode in vbscript for mach3
    By revolucion in forum Visual Basic
    Last Post: 05-30-2015, 12:00 AM
  2. trying to convert probig script linux cnc in vbscript for mach3
    By revolucion in forum Digitizing and Laser Digitizing
    Last Post: 01-16-2015, 05:12 AM
  3. Mastercam vbscript execution
    By vortxx in forum Visual Basic
    Last Post: 03-06-2012, 05:32 PM
  4. VBScript Documentation for Mach3?
    By fatal-exception in forum Mach Wizards, Macros, & Addons
    Last Post: 09-19-2007, 03:52 PM
  5. VBScript
    By DAB_Design in forum Mach Software (ArtSoft software)
    Last Post: 02-21-2005, 02:19 PM
