I started to program a new WJ200 VFD based on the following post: http://www.cnczone.com/forums/spindl...e-hitachi.html
My problem is that I cannot access all of the programming code. For instance, when I try to go to A062, it will not let me enter a setting, as if I have entered an invalid setting code. I can set the basic settings without an issue (A002, A003, etc.)
In another post, a user complained that he wasted hours before learning that you need to "unlock" higher functionality.
Additionally, I am unable to use the F001 setting to adjust Hz to try to run the motor - presumably because the other settings have not been inputted.
Thanks!
Shawn
