Hello, everyone! I have been lurking for a little while. I have a pretty standard Mini Mill, with a belt drive conversion. I am in the process of beefing up the column, base, and column-base interface with about 100lb of steel for increased rigidity.
I recently purchased a 1.25" indexable end mill that has two TPG322 carbide inserts. I reasonably understand the nomenclature, but I have a couple of practical questions:
First:
TPG321 = 1/64" radius
TPG322 = 1/32" radius
TPG323 = 3/64" radius
TPG324 = 1/8" radius
As I understand it, a larger nose radius on the cutters means better finish (at a given ipm / rpm), but at the expense of greater stresses on the tool, spindle, and machine. I mostly bought and have used this cutter for facing sides, with cuts of .020 DOC max, and .001-.003 for the finish pass, with great results in AL and pretty good results in steel.
So, my first question: in my light-duty mini mill (and what Id probably call light-moderate duty after the modifications are all done), would anyone recommend stepping up to the 323 or even 324 cutters for face milling only?
Secondly, would you recommend TNG ("N" meaning "Negative Rake") over the TPG cutters for working mild steel? I used the factory TPG322 cutters on steel with pretty good results (aluminum finish was smooth as glass--this was smooth but with obvious tool marks), but would I see better results or appreciably-longer cutter life with TNG inserts?
Thanks!
