586,070 active members*
3,482 visitors online*
    Feb 2015
    4
    LinuxCNC arrow keys won't move table
    I've had a Smithy 1240 running successfully with LinuxCNC for a couple of years. It seemed like a good idea to move to LinuxCNC v2.7 and installed a clean version of Ubuntu 12.04. The 1240 configuration file is native to LinuxCNC so I didn't save the HAL or INI files when installing everything fresh.
    LinuxCNC will turn machine on, and it will turn the spindle on. The machine will home but the arrow keys will not move the table nor will the G0 commands or MDI commands move the table. It doesn't return an error when a command to move the table is sent.
    It seems like the right com port is selected because it homes, and the steppers are getting power and direction signals because the machine went home correctly. Because the spindle turns on and can be accelerated to normal speeds suggests the port configuration is probably right. The arrow keys, keyboard, and mouse work normally in Ubuntu so those pieces of hardware are probably not the problem.
    Thinking it was a problem with 2.7, I re-installed a new version of Ubuntu and put LinuxCNC 2.6.10 on the system. The problem remains the same.
    Any suggestions what might be a problem? I've spent the last four days fiddling with the software, but have had no success.
    Feb 2015
    4
    Re: LinuxCNC arrow keys won't move table
    New info on the jogging problem. An entirely different computer with a fresh installation of Ubuntu 10.04 and LinuxCNC 2.5 produced the same problem. When the arrow keys are pushed, the radio buttons which select the x and y axis (for touching off) are selected instead of jogging the table the table.
    With the new computer, the X, Y, and Z axis move to their home position when asked.
    Does anyone have suggestions or theories?
  1. Mach3 arrow keys don't work
    By VSturmer in forum Mach Software (ArtSoft software)
    Last Post: 09-02-2015, 01:11 AM
  2. Arrow keys won't jog anymore
    By SSN Vet in forum Mach Software (ArtSoft software)
    Last Post: 11-23-2013, 01:40 AM
  3. Installing LinuxCNC without a complete OS install
    By DieselTwitch in forum LinuxCNC (formerly EMC2)
    Last Post: 12-09-2012, 01:22 PM
  4. jogging with arrow keys failed on new screen
    By johnh in forum Screen Layouts, Post Processors & Misc
    Last Post: 10-01-2009, 11:56 AM
  5. Arrow keys backwards and sideways
    By IQChallenged in forum Machines running Mach Software
    Last Post: 05-30-2007, 12:33 PM
