586,103 active members*
3,648 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > chinese spindle at low rpm?
Results 1 to 10 of 10
    Nov 2005
    24
    hello everyone,
    can someone who has the "chinese" 2.2 kW + VFD answer a simple question?
    I am going to buy one because i want to be able to make some machining at about 2000-3000 rpm, or even much less (40-60 rpm) if I want to use a fly cutter, but looking around in the various forums it seems anyone use them at very high speeds, like 18000 or 24000 rpm... now the question is: I understand the air cooled version will overheat at low speeds, but if I get the water cooled one, what is preventing me to run it at 2000 rpm?? not enough power? has anyone actually machined something at this low rpm with those spindles?
    Thank you for your help, I looked everywhere for this and did not found any useful info
    www.cloxart.co.uk
    May 2015
    1422
    Re: chinese spindle at low rpm?
    Advice from the supplier of mine was to never run it below 6000rpm at load.
    I fly it at about 1000 for edge finding, it will run at 3000-4000 ok when I'm milling mild steel with it but it's really light cuts or the thing just stalls. And I have no idea what running it slow is doing to the bearings, the coils or the VFD driving it. So I tend to avoid it where possible.
    Nov 2005
    24
    thank you Dharmic
    www.cloxart.co.uk
    May 2015
    1422
    No dramas.
    Horses for courses and it sounds like your course is a much more traditional application and arrangement that calls for the bigger, heavier, lower RPM and higher torque motors.
    In fact, if you're going for both 2000-3000rpm and down to 60, I reckon you're going to be looking for something chunky with a multi-range gearbox.
    the spindles have very little torque below 6000rpm - at least with the usual VFDs (vector control VFDs can increase torque significantly - but still can't do magic).
    Its just a simple 2 pole induction motor with rather light bearings - it is not designed to run slow.
    For low rpm / high torque applications more poles and stronger bearings are required.
    Christian
    My CAM Software and CNC Controller: www.estlcam.com
    15362
    Quote Originally Posted by gianluca70 View Post
    hello everyone,
    You did not find any info because they can not safely run that slow, lots have tried but most end in failure
    The spindle is not designed to run this slow, to get it to run slow you would have to have a low minimum Hz setting, and for these spindles 100Hz is the minimum you can safely use, anything else and the spindle will overheat and eventually destroy itself
    Mactec54
    24221
    Albert E.
    Nov 2005
    24
    I was thinking the minimum of 100 Hz applies only to the air cooled one... thank you anyway to all for you, useful information. I will probably get it it anyway so at least I can hopefully solve the problem of the noise that I am getting from my current spindle
    www.cloxart.co.uk
    15362
    The air cooled spindles is around double as the minimum setting so if it is a 400Hz spindle it would have a minimum of 200Hz
    Mactec54
    Oct 2015
    4
    hello everyone,
    2000 to 3000 yes it will be usable even at 1000 rpm with correct vfd/motor size and setup, but for 40-60, it wont even spin, go for stepper motor as spindle
  1. Mini Mill X2 Spindle Head + VFD + Chinese Spindle= custom!
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2016, 10:04 PM
  2. CHINESE SPINDLE 2.2KW
    By Ed Williams in forum Open Source CNC Machine Designs
    Last Post: 03-29-2016, 04:07 PM
  3. CHinese 2.2kw spindle low rpm
    By devil2000 in forum Phase Converters
    Last Post: 05-10-2011, 10:30 PM
  4. chinese spindle
    By roger de poger in forum DIY CNC Router Table Machines
    Last Post: 05-02-2011, 12:43 PM
  5. Chinese Spindle/VFD Help
    By swaggs21 in forum DIY CNC Router Table Machines
    Last Post: 01-12-2011, 02:25 AM
