586,061 active members*
4,303 visitors online*
Thread: VFD settings
    Dec 2014
    16
    VFD settings
    I am building a cnc with a 2.2kw VFD. I am controlling it with a relay on by breakout board through Mach 3. I cant get the spindle to come on. My Question is,
    1. What should PD001 and PD002 be set at
    2. how does the VFD hook up to the breakout board properly.
    3. How to set it up in mach.
    I have tried different things but just cant get it to work. I can however get it to spin wile PD001 is set to 0. Any advise would be helpful.
    15362
    Re: VFD settings
    Quote Originally Posted by Rileigh View Post
    For external control PD001=1 0 is for the Keypad control
    PD001=1
    PD002=0
    Do you have the PWM working on your Breakout Board, you need a 0-10v from this output
    Mactec54
    Oct 2015
    4
    Re: VFD settings
    hello,
    1st, your relay goes on off, will you applying the rpm from the knob,, u need another connection to send rpm frequncy to your vfd, and this could be done in different ways
    0-10v
    modbus
    some accept high speed pulse input,
  1. DSP settings
    By rocabig in forum Excitech routers
    Last Post: 07-14-2016, 07:40 PM
  2. re : settings
    By Gary Cooper in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-03-2012, 09:55 PM
  3. How to keep my settings
    By stinkfist in forum Solidworks
    Last Post: 08-08-2011, 01:22 PM
  4. Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 05:45 PM
  5. dnc settings
    By jamesr in forum Fanuc
    Last Post: 02-02-2006, 09:13 PM
