586,100 active members*
2,627 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Vertical Mill, Lathe Project Log > Field weakening control of Siemens DC 1GL5 motor EMCO 120P Spindle
Results 1 to 5 of 5
    May 2007
    10
    Hi all
    Most have replaced the DC spindle with an AC + VFD drive. I decided to take the less travelled path and keep the original spindle.
    Briefly this is how it is supposed to work:
    0 RPM->1700 RPM: field voltage constant at 310VDC.
    Varying armature voltage from 73VDC to 400VDC at constant current yields constant torque output, 50RPM to 1700RPM
    1700->6000 RPM: armature voltage constant at 400VDC.
    Reducing field voltage from 310VDC to 73VDC yields constant hp output, 1700RPM up to 6000RPM
    The ABB DCS402.075 is the drive I am using. Full of features but commissioning is not for the light hearted (using rs232 and DWL software)
    The EMCO transformer provides 333V 3 phases (coincidently the 120P can go up to 5000 rpm which is 333V DC via interpolation). The ABB DC drive calls for 380V 3phases.
    I plan to use Mach3 + ESS + C32 (cnc4pc) for the retrofit. I did an emco Mill this summer and all worked out fine.
    I will use the Analog ouput (10V) from C32 (port VFD) to control the spindle speed.
    Got
    The original Encoder has 4 wires: 0V, 5V, 360PPR and 1 PPR while the ABB DC drive calls for A+/- B+/- Z+/- 0/5V but accepts single ended encoders.
    So 360ppr wire to A+ should suffice for speed control ? I was told to connect 1 PPR to B+ ... not sure about it.
    ABB Drive details:
    ABB DCS400
    thanks for any pointer.
    May 2007
    10
    Re: Field weakening control of Siemens DC 1GL5 motor EMCO 120P Spindle
    Field Weakening with ABB DCS800 DONE with original Siemens GL5104-OEZ40-6JU7-Z DC motor.
    Apr 2007
    68
    Quote Originally Posted by darenfs View Post
    Hi all
    Got
    ABB Drive details:
    ABB DCS400
    hi, were you able to get this working? I thought about using the DC motor but the extra transformer and the initial cost of the ABB scares me. I saw one retrofit using the Eurotherm 514C which are much more reasonably priced, do you know if those would be a reliable unit?
    May 2007
    10
    Yes it works fine. I had to add an encoder on the motor shaft. I have an extra ABB DC drive 2Q. Let me know if you want to tackle this fun project.
    Nov 2005
    218
    Still have this?
  1. Emco 120p Rebuild
    By slowtwitch in forum Vertical Mill, Lathe Project Log
    Last Post: 10-30-2021, 09:46 AM
  2. emco turn 120p with emco tronic ti control
    By rcjacob in forum Vertical Mill, Lathe Project Log
    Last Post: 03-26-2014, 05:01 PM
  3. Replies: 0
    Last Post: 11-22-2013, 07:49 PM
  4. Emco 120p grease??????
    By slowtwitch in forum EMCO Lathe
    Last Post: 12-07-2011, 05:26 PM
  5. Solid State DC Motor Controller with Field Weakening
    By beelindustrial in forum News Announcements
    Last Post: 06-05-2011, 06:38 PM
