Recently, I purchased a chinese spindle to mount in place of my router. After figuring out my current break out board could not control the spindles VFD for speed control, I purchased and installed a new break out board. I got everything set up (spindle, limits, touch probe, etc) tested and working great.
While waiting for some aluminum to arrive so I can cut out brackets to hold the new spindle, I decided to try out a craving.
This is the first run of g-code using the new break out board. Now I notice I have stepper motor issues, but only with the Z axis.
The Z changes at least 1/4 inch deeper into my project all of a sudden. So I hit the E Stop. So after screwing up my work piece
a dozen different times I noticed something.......
In the beginning, problems started out around half way through one step of the project.
As soon as the machine runs G code, the spindle starts to lose it's z position.
After continually trying to figure out the problem I notice the lead screw moving when it's suppose to be holding the current position.
Would there be possible interference when I installed the new break out board? I had no problems like this with the previous board.
It also appears to only move when the X axis is moving in the negative direction.
I attached a short clip so you can watch whats happening with the Z axis stepper/lead screw.
