586,116 active members*
3,386 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Will this computer run pathpilot?
Page 1 of 2 12
Results 1 to 20 of 33
    Feb 2007
    1538
    Hi folk.
    Computers are not my strong point and I don't want to embark on anything to complex.
    I want to install pathpilot on my other 1100 now ,However to import a new Tormach controller into NZ with the current exchange rate, freight and other fees will be about $1600.00 NZ....ouch!
    So I am wondering if my 2007 Dell dimension C521 with XP would suit. It looks like it would accept a Tormach PCI card in the one slot... if I remove the modem card. See pics.
    That way I would only need to import a Tormach pathpilot PCI kit for a fraction of that cost.
    Expert advise most welcome. Please note if it is risky or difficult please tell me!
    Cheers keen
    Feb 2008
    644
    Re: Will this computer run pathpilot?
    The answer is a resounding....
    probably.
    You will likely need to turn off most power management options in the BIOS, like "Cool and Quiet", and cstates above C1 etc
    Jun 2014
    1780
    Quote Originally Posted by PCW_MESA View Post
    probably.
    It doesnt cost much to try, other than the mesa card. I am thinking about using my old Dell 8200 to try the same thing, just to have for a spare......
    mike sr
    Feb 2007
    1538
    Thanks PCW-MESA.
    OK so the BIOS is accessible when it boots up isn't it?
    I note Tormach recommend x86 (32) bit architecture ....whatever that is.... and my dell seems to be a " C521 Athion(TM) 64, desktop processor 3500+...whatever all that is....
    Tormach also recommend a Intel chipset... and the Dell is a AMD Athion 64 label?
    Any translations and explanations welcome.
    Keen
    Oct 2006
    323
    You can always download LinuxCNC to a bootable CD or burn it to a thumbdrive. You can than trial run LinuxCNC and run the Latency test (LinuxCNC Documentation Wiki: Latency-Test).
    I didn't see your particular Dell listed in the posted results, but running off a LiveCD or bootable USB will keep your Windows box intact until you have confidence that the PC hardware is up to task. Other common problem areas are on board video/audio or video cards and as PCW mentioned BIOS settings. It is easy and free to try before you buy anything. If unhappy with your current PC, the listed results for motherboards should help you find a decent choice lying around or if you need to shop around.
    Oct 2006
    323
    The Intel chipsets, usually on board video and audio, have a pretty good track record of working well with LinuxCNC, therefore the preference.
    Feb 2007
    1538
    Quote Originally Posted by 123CNC View Post
    Thanks 123. Can you explain a bit more what a bootable USB /live CD is - I have a 16GB USB 'key' .... it that it? I also have 52x CD-R 700 MB.....would that work...if so, how would I do that?
    keen
    Feb 2006
    7063
    Unlike Mach4 using the PP, LinuxCNC/PathPilot using the Mesa board should be relatively un-fussy about the specific motherboard being used. It is the Mach3 PP driver that is primarily responsible for most MB-related problems. When the PP is eliminated, and replaced with a motion controller, even Mach3 can be configured to work well with almost any PC, including most laptops. I would bet the Dell Dimension would work just fine with PathPilot.
    Regards,
    Ray L.
    Dec 2013
    267
    From the looks of your picture, it looks like the motherboard in your Dell has both a PCI and PCI-e port available.
    Why not borrow the Mesa card from your other Tormach temporarily to test it out? If the Dell has anything important the hard drive, make sure to back it up or swap it out before installing PathPilot, as the PathPilot installer will image over your drive and effectively erase everything on it. This would give you positive confirmation that the PathPilot upgarde kit would work before you order it.
    For what it's worth, the Linux kernel is really not very picky driver-wise about underlying hardware. You should be just fine with just about any 64bit machine. I have had 0 hiccups with my controller PC that I threw together with some old junk. I saw a recommendation above about running a 32bit processor, but the Tormach-provided image runs just fine on my 64bit proc.
    Feb 2007
    1538
    Thanks Guys!
    You have all been a big help.
    I have just pulled the side off my old XP (CPU 1000 - Intel chip -XP ) currently running Mac3 on my old 1100 - and it has a PCI card also. So I have a back up plan if the Dell plan A does not work - I can then try the Mesa card in the old controller and it may run for a few years like that. It was originally checked for the pulse stream thingy and it was good.
    - So I have purchased the PCI Mesa from Tormach and will let you know how it goes in a week or two when it arrives.
    Cheers Keen
    Feb 2007
    1538
    Quote Originally Posted by wtopace View Post
    Thanks - Yes I though about borrowing the Mesa card - but if I had any issues that I did not understand and could not undo ..........I might be in stress city with urgent work coming in.
    Keen
    Oct 2006
    323
    Quote Originally Posted by keen View Post
    keen
    The 700 MB CD will be too small, need at least a DVD (~2.4 GB or larger). If you do get a DVD, you'll need to download the LinuxCNC Live-CD and using Infrarecorder or other CD/DVD burning software, burn the .hybridISO (ISO image file from download) to the DVD.
    Your 16 GB USB key would work fine, but empty it first so that you can burn the ISO image to it. If working on a Windows PC, you'll need to download and install Imagewriter (Win32 Disk Imager download | SourceForge.net). After you download the LinuxCNC ISO http://www.linuxcnc.org/linuxcnc-2.7-wheezy.iso (latest version, or go to LinuxCNC.org and locate an earlier version if you like). Then use the Win32 Disk Imager to move the .hybridISO file to your USB. Make sure your Dell is setup in the BIOS for USB boot, power down, install USB key with ISO image and reboot. A prompt selection should appear and select the Try It without Install item.
    LinuxCNC is generally not to picky on the hardware side, but it doesn't hurt to test and check before going to all the trouble of wiping out a Windows box that won't work or at least not work well. It may be best to keep the Windows machine a Windows machine if you get unlucky with your Dell.
    Oct 2006
    323
    Quote Originally Posted by SCzEngrgGroup View Post
    Regards,
    Ray L.
    Generally LinuxCNC is not too fussy, and typically works very well with the parallel port and PCI/PCIe cards. I believe the hardware and motherboard issues boil down to conflicts with the real time kernel and hardware level interrupts. I have run into a few PCs that even after all of the work-arounds to mitigate video issues and other realtime improvement hacks still had 100,000+ microS latency, not good at all. Again, real problems are likely far and few between, but it just might pay to look first before you leap.
    Feb 2007
    1538
    Hi Guys.
    Well the Tormach PCI arrived today and I managed to successfully install Pathpilot on the Dell. Yeeeehaaa !
    I had a couple of issues that I though seemed terminal - a real headache for my old brain......but I managed after a couple of hours of trial and error, to get it all working, more by luck than a good understanding of exactly what I was doing. It did not want to complete the initial install...but finally it did, and then it just froze on the Tormach logo - but I eventually discovered it was only the BIOS time setting that was incorrect.....Yaahooo!
    It seems to run very fast and smooth compared to mach3 - and it is installed on a series one! fantastic !
    A couple of questions: Is that enough to be sure it is running fine...or is there a test I should do?
    Also I cant see how to get it to auto boot when the power is switched on. I have trolled through the BIOS settings but cannot see any obvious setting - am I missing something or is it just not available on that Dell?
    Keen
    Jun 2005
    656
    On most Dells, the BIOS setting for what to do when external power is applied is called "AC Recovery" and you want it set to 'on'. Some low-ends models don't have it but a quick look at the C521 Setup manual indicates it should be there.
    Feb 2007
    1538
    Thanks Shred.
    I needed to permanently install the Dell this morning, including making a Mesa plug plate to fit it.
    Anyway when I plugged it all back in and switched the power on - it auto booted!....magic...I had not even got to the BIOS setting stage!
    For those of you still on Mach3 and procrastinating about pathpilot....DO IT ! It is a big step up on so many levels. Quicker...smoother...the interface.....the soft limits!.....passive probe facilities.....!
    Cheers Keen
    Feb 2007
    1538
    Quote Originally Posted by bevinp View Post
    Keen,
    You're always going on about the passive probe even when it's barely relevant. Remember Fawlty Towers... "don't mention the war".
    Bevin
    PS. Well done on getting PP installed, I will be installing it on my series 1 soon. And I am .surprised you have time to fiddle with the PP (aka Passive Probe) as well.... oops I mentioned it.
    Hi Bevin - without mentioning the war, do you have a 'PP' I didn't realise what they could do until I bough and tried one .....with the easy use facilities of pathpilot they are fantastic for my type of toolmaking/mouldmaking work where setting up is a big part of the job. ....'road to Damascas'
    keen
    Feb 2007
    1538
    So if my recent install of pathpilot on the Dell sounds sweet and is fast - is that enough?...or should I run some sort of test to check it is stable?
    Keen
    Jun 2006
    340
    keen
    Hi Keen,
    'Road to Damascus'. Wasn't that a Bob Hope movie? So you must be having lots of laughs.
    Yes I have PP and yes it is a handy tool. Fortunately my hobby work doesn't need the accuracy your toolmaking requires so the Passive Probe as-is works within my tolerances. But yes I certainly want one of your stems, because of the accuracy (makes me feel good) and because I'm sure i will break mine sooner or later.
    Bevin
    Jun 2006
    340
    Keen
    Maybe set the part zero to a known measured position, cut-air a program with a very busy toolpath, and then try to overload the Dell by viewing PP graphics and typing madly on the keyboard or whizzing around within PP Then remeasure part zero. And not to mention the war again, for the measuring you could use your PPP (Performance-enhanced Passive Probe with your new super master take-no-prisoners stem).
    Bevin
Page 1 of 2 12
  1. PathPilot Beta is over
    By tmarks11 in forum Tormach PathPilot™
    Last Post: 04-09-2015, 02:52 AM
  2. PathPilot V1.6
    By adamboon in forum Tormach PathPilot™
    Last Post: 03-26-2015, 12:33 PM
  3. Replies: 8
    Last Post: 08-20-2014, 07:16 AM
  4. What is the difference between an industrial computer and a normal computer?
    By Apples in forum Controller & Computer Solutions
    Last Post: 09-18-2008, 10:27 PM
  5. fast computer as server, slow computer as terminal
    By replicapro in forum Computers / Desktops / Networking
    Last Post: 07-01-2004, 08:05 PM
