586,102 active members*
2,367 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Interact 1 Mark 2 Electrical drawings
Results 1 to 6 of 6
    Oct 2015
    4
    Wondering if anyone could help us we are trying to source the electrical schematic drawings for our Bridgeport machine. The legend plate states the drawing number 879-130E. Any help would be greatly appreciated.
    Oct 2015
    4
    Re: Bridgeport Interact 1 Mark 2 Electrical drawings
    Has nobody any idea where we may locate this diagram?????????
    Mar 2007
    2083
    I don't know this helps but
    I found this diagram
    Attachment 294910
    Attachment 294912
    when I replied to
    http://www.cnczone.com/forums/bridge...ing-fuses.html
Name:	bridgeport tagboard 24v regulator.jpg
    I've added extra info on the diagram --
    1 -- 24V regulator circuit
    2 -- and low way lube can trigger a low 24V alarm !
    also
    http://content.heidenhain.de/doku/om...b/23268625.pdf
    http://content.heidenhain.de/doku/om...b/sa151155.pdf
    http://content.heidenhain.de/doku/om...b/22504128.pdf
    John
    corrected version of 2nd half of schematic -
    in the 24V regulator circuit . the positive capacitor terminal should go to the diodes cathode
Name:	interact_2 corrected reg.jpg
    Oct 2015
    4
    Quote Originally Posted by john-100 View Post
    Attachment 294910
    Attachment 294912
    when I replied to
    also
    John
    Thanks John,
    We will check the diagram against machine and see if it resembles what we have.
    in the mean time thanks for taking the time to help it is appreciated.
    Andy and Jamie
    Mar 2008
    60
    This is the info on my machine.
    LOOK very closely to see if it matches.
    Oct 2015
    4
    Hi bk1955,
    Just a short note to say thanks for your reply to our thread, At first glance it looks as though the diagrams that you have posted are the correct ones for our machine. We will investigate further when we have a break in our maintenance duties. In the mean time once again thanks for your time and effort in helping us.
    Andy and Jamie
  1. Bridgeport Interact 2 Mark 2 TNC 151 with no prams
    By CK1 in forum Bridgeport / Hardinge Mills
    Last Post: 01-26-2015, 08:32 PM
  2. Replies: 2
    Last Post: 07-17-2014, 02:58 PM
  3. Simoreg electrical drawings
    By SBAGHAEI in forum Servo Motors / Drives
    Last Post: 10-08-2009, 07:03 AM
  4. BP Interact 1 Mark 2
    By hancockj in forum Bridgeport / Hardinge Mills
    Last Post: 03-12-2009, 01:26 PM
  5. Need electrical drawings!
    By mte.jalal in forum Cincinnati CNC
    Last Post: 10-15-2008, 10:05 PM
