586,089 active members*
3,885 visitors online*
Results 1 to 3 of 3
    Sep 2011
    78
    shopturn option or standard
    Hi there,
    Just got an old Monforts Unicen 500 installed at work with sinumerik 840d controll.
    I also got a bunch of manuals on a usb stick with the machine, it also contains numerous manuals regarding shopturn but i cann't seem to find out if this is installed on the controll.
    Is shopturn a option or is this a standard part of the controller??
    Same question regarding autoturn, standard or option.
    My first siemens cobtrolled machine so everything is a bit confusing at the moment.
    Jan 2006
    121
    Re: shopturn option or standard
    Hi duivenhok,
    have you gotten any answers to your questions from others, or in private e-mail.
    I have almost the same question about just ShopTurn is an option, and if you can buy or copy it from someone.
    My lathe is an Emco Concept Turn 155 with driven tool and even a C-axle.
    Jan 2006
    121
    I was in contact with Siemens in Sweden and it is an option but it can be in your machine but may not be enabled.
    If it is missing, it costs about 700 USD. If it exists, and only needed to be activated, it can be solved in 2 different ways.
    Either over the phone or to service staff visit you.
    Call Siemens support and ask what applies to you.
    Good luck
    Dan
  1. m30 program shopturn 810
    By Ph2011 in forum SIEMENS -> GENERAL
    Last Post: 05-13-2014, 10:15 AM
  2. Test Siemens shopturn PP
    By echtdampfer in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-20-2013, 08:47 PM
  3. EMCO E45 sinumerik 810 ShopTurn HELP!
    By DULLE in forum EMCO Lathe
    Last Post: 04-26-2012, 06:18 PM
  4. 840d ShopTurn tailstock programming
    By kkronja in forum SIEMENS -> ShopTurn
    Last Post: 09-24-2011, 10:24 AM
