586,096 active members*
3,626 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > kITAMURA MYCENTER-1 Help needed again!!
Results 1 to 9 of 9
    Feb 2004
    93
    Hi There,
    We have a kitamura Mycenter-1 with an Arm type tool changer. A tech from Fanuc america come here this morning to fix it, he told us that the macro program (9000) are missing.....
    Does someone had a similar machine with a fanuc OM controller that could send us their 9000 program??
    The year of the machine is a 1990 serial 2192.
    Any help appreciated,
    Alex
    Alex
    www.ebfcnc.com
    Sep 2005
    26
    You can put your own program into the 9000 level programs.I'm not sure about the om,though.You need to enable parameter write in settings and set a parameter(6076?) which is attatched to a program number.You can use sub call by m or macro call by m.I'm surprised a fanuc rep could not do this for you.It is in the manual.
    Nov 2004
    53
    Do you have the hard copy of the macro? and just need to put it in?
    If you dont have the hard copy you have a big problem especially if any pmc data was being used in the macro.
    If you dont have it someone will have to write it that can look at the ladder and write the macro.
    Usally on arm type changers there are two 9000 programs dealing with it.
    If the pmc is not involved ...
    and the changer uses switches or an encoder and knows where it is , it would be easy to write as you are dealing with two positions in Z axis.............one being the Z home and the other being G28 position.
    Does your machine have a readout the gives the current pot position and the current tool in spindle?
    If an encoder or switches are not used it gets complicated as there a few things needed to be done in parameters to make the tool versus pot to be correct.
    I just went thru this with a customer and it was crazy the way the macro was done.
    Why cant the builder give you the macro?
    Good Luck
    Nov 2006
    14
    please contact [email protected]
    Jul 2003
    263
    set parameter 6076 to 6, write program #O9006 each time the machine sees a M6 it will call sub O9006
    parameter3202 bit #4 will allow you to unlock your 9000 series program
    remember to LOCK it after you are finished editing!!!!!!!!!!!!!!!!!
    sample program
    O9006
    G91G28Z0M5
    M19
    M6
    M99
    If you can ENVISION it I can make it
    Jun 2007
    Hi, I am shahid,
    I have a Kitamura mycenter-1 equipped with Fanuc 3M Control. I dont have the exact paramters. I have put the dummy parameters, calculated by myself, but the spindle is not working. Rest of the machine is ready. Can any body help me in this respect. Thanks.
    Shahid Riaz
    email: [email protected]
    Re: kITAMURA MYCENTER-1 Help needed again!!
    I can support you:
    [email][email protected]
    Quote Originally Posted by Badr1988 View Post
    I have the sane problem on Kitamura mycenter 2x with yasnac i80.
    Any help
    I have the same machine with yasnac do you have the tool changer program ?? Can you help me ? My email [email protected]
    - - - Updated - - -
    Any help
  1. Kitamura Mycenter 3
    By machinescnc in forum Uncategorised MetalWorking Machines
    Last Post: 10-08-2012, 11:59 PM
  2. kitamura mycenter 6
    By homa in forum Kitamura
    Last Post: 05-13-2011, 08:22 AM
  3. Kitamura Mycenter
    By cdlenterprises in forum Uncategorised MetalWorking Machines
    Last Post: 11-20-2007, 05:25 AM
  4. Kitamura Mycenter 3B
    By sebaja in forum Uncategorised MetalWorking Machines
    Last Post: 10-16-2007, 11:22 PM
  5. Kitamura Mycenter 0
    By inertialabs in forum Shopmaster/Shoptask
    Last Post: 01-16-2007, 03:47 AM
