Originally Posted by
Bird_E
digits - I don't have the diameter handy. I will see if I can measure it tonight.
Greolt - Yes that is the original motor, just a new paint job!
Yes it is an air blast, I do mostly dry machining the air blast does a great job at keeping chips away from the cutter. There is a solenoid in the column enclose that I drive with Mach3 coolant on and off. The hole in the nozzel is small only about 1/16th. I keep the pressure set to about 20 PSI and and seems to be plenty to keep chips away, and not too much where my compressor is running all the time.
Sorry about the photo size I will fix that!
Bob
