Originally Posted by
JPowell
Ok, I will try again to continue.
It was just a axis that was out on the board. The China board has all drivers on a single board, I suppose it could be possible to use y to drive a, I don't know. After searching many threads and discussing the issue with some cnc suppliers everyone seems to be of conclusion it was the board anyhow.
I am a pretty determined type of person, so I just went for a total electronics rebuild and it wasn't as hard as I thought. I contacted buildyourcnc and the sold me a bob and 4 drivers. It's a very nice system which in some ways resembles how my syil x5 is set up inside. First thing I tackled, seemed logical to me, was reworking the inside to fit the parts. It wasn't possible to use the parallel hole in the machine. There us an aluminum L bracket with a board on it, and there is 4 spacer screw nuts inside the machine. I was able to use these parts, drill a few homes a mount the new Bob to that. The 4 drivers seemed to fit if I stacked them 2 wide and 2 tall. I used a piece of aluminum inbetween to build a sandwich. This tower of drivers was a bit to tall, but there's room to raise the power supply 1/2" which allows everything to fit nicely inside. After figuring out how it will all fit and mount, I pulled out the parts and wired them all. There were lots of online instructions so it was surprisingly easy!
Another side issue I had with this machine was the spindle would shut down with an error if my AC unit came on or if I turned on the lathe. The plug and switch inside has male tips that the wires clip to and they were not a tight fit, and there's no ground wire inside. I added a ground wire and soldered the power connections. This bit of work did solve the spindle issue immediately.
I cut a hole in the panel cover for the parallel port. I also like this because it lets some air flow out, which could be the route cause of the original electronic failure, certainly possible. Inside the panel I was sure to tape a piece of paper with all my new Mach settings.
If you use the buildyourcnc electronics and keep the x,y,z steppers that come in the machine, you will change ports pins. X is 2,3, y is 4,5 z is 6,7, a is 8,9. Then two columns over you enable the corresponding red x's to be green check marks.
In motor tuning, x,y,z are 4064 steps with the drivers dip switches at 1/4. I find about 100 velocity and 1 accel is working nice.
The eBay 50:1 gear drive 4 axis is also set at 1/4 on the driver dip switches. The steps are 111.111, around 600 velocity and 25 accel.
Hopefully it lets me post some pictures
