586,035 active members*
3,754 visitors online*
    Oct 2015
    4
    New PC - parallel ports differences
    Hi all!
    I finally jumped in and bought a 6040 CNC machine.. mostly for hobbiest use and to learn..
    However I'm now looking at what PC to pair it with.
    I'm not 100% sure on what software I'll be using yet but may perhaps use Mach3 as it seems to be the most popular..
    In regards to the PC, I'm thinking at this stage that I'll do a dual boot with XP 32bit for the CNC side.. and a fairly powerful windows 7 side.
    I'm currently thinking I want a motherboard with:
    i7 cpu.
    USB 3.0
    Parallel port
    Serial port
    Dual PS/2 ports.
    However upon searching, I'm wondering is there any trap I should look out for when searching for parallel ports? There's blue or pink varieties.. are they the same?
    I've read somewhere about some providing a lower voltage.. is there a way to confirm this beforehand or is it only PCI adapters that do this?
    Re: New PC - parallel ports differences
    The color of the port means nothing.
    One thing I'd be concerned with is that it's unlikely that you'll find XP drivers for any modern motherboard.
    Oct 2015
    4
    Ah thanks. Yes it's nigh on impossible it appears so I'm mainly looking at refurbished H61 motherboards. Think I've found one in the Asus H61M-Pro. Seems to have everything I need and has XP drivers
  1. Parallel Ports
    By DY123 in forum Momus Design CNC plans
    Last Post: 11-11-2012, 03:44 PM
  2. 2 Parallel ports
    By DrStein99 in forum LinuxCNC (formerly EMC2)
    Last Post: 08-12-2010, 01:58 PM
  3. Parallel Port differences
    By boyvox in forum CNC Machine Related Electronics
    Last Post: 10-12-2005, 04:38 AM
  4. Parallel ports
    By itsme in forum Computers / Desktops / Networking
    Last Post: 10-01-2005, 02:20 AM
  5. 3.3 V vs. 5 V TTL on parallel ports
    By HansM in forum DNC Problems and Solutions
    Last Post: 07-28-2005, 08:28 PM
