586,224 active members*
3,703 visitors online*
    Sep 2015
    Can a bad tube burn up a power supply?
    So I took the plunge and bought a KH7050B laser cutter. This is my first laser cutter so I don't know much about them as far as the laser parts go. My question is this, I was pulsing the laser checking mirror alignment and the laser quit firing, I checked my power settings,and tried to fire it a couple more times, and the laser wouldn't fire.I checked to make sure that the Laser PSU had power and it was on. I cycled the power on the machine, laser still wouldn't fire. Then the power supply shut down and wouldn't power up. The fuse blew on the power supply, I tried replacing the fuse and it blows as soon as it turns on. I am prepared to replace the power supply but then I was wondering if the tube could has caused the power supply to go out. I don't want to burn up the new power supply if this tube is bad. Thanks for any help.
    Nov 2010
    787
    Re: Can a bad tube burn up a power supply?
    Which power supply? Main or laser power supply?
    CNC lasers, constructions, service
    Sep 2015
    the laser power supply.
    Nov 2010
    787
    You may check it without laser. Just switch machine off, wait 15-20 minutes to clear PSU from power, disconnect anode (red) cable from laser and isolate it very well.
    For 100% sure and safe put red cable`s end into a dry glass bottle. Take care with the laser, it is very fragile.
    Than insert new fuse and press test for a moment. Nothing should happen.
    If this time fuse will survive you will make another test.
  1. Rapid Loss of Cutting Power- New Tube, Fairly New Power Supply
    By scrappyjedi in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 02-23-2016, 01:24 AM
  2. 60W co2 tube on 40W power supply?
    By Pairair in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-03-2015, 10:26 PM
  3. Laser tube and power supply 40W co2 and 60w co2
    By Yaro in forum RFQ (Request for Quote)
    Last Post: 07-18-2014, 08:36 AM
  4. Using a 80w tube with 150w power supply?
    By gfacer in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 10-31-2012, 12:06 AM
  5. Is it the tube? Or the power supply?
    By SimonArthur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-20-2008, 06:36 PM
