Re: Encoder Index and Z channels?
Originally Posted by
engnerdan
So to add to this and better define the differnece between a BLDC and a AC (induction motor). A BLDC motor will have an rotor (the shaft assembly) made of a permanent magnet. An AC motor, which is properly called an AC Induction Motor, will have a rotor made of steel laminates and often aluminum.
-Dan
Yes if you notice I said AC servo's not induction motor.
BTW the rotor of an induction motor has embedded aluminum bars acting as shorted turns, they were at one time made of copper.
SwampD the commutation of a AC servo is often done with a resolver or other means rather than the three commutation pulses,
You can turn a AC servo into a BLDC by fitting the 3 commutation pulse encoder.
Al.
Albert E.
