586,052 active members*
4,261 visitors online*
Results 1 to 10 of 10
    Feb 2007
    1538
    SHARE YOUR SUB ROUTINES
    Hi Folks
    Please share your knowledge on sub routines.
    I am a beginner on this subject and am keen to learn more.
    I start the ball rolling with this video:
    Cheers keen
    https://www.youtube.com/watch?v=mOmy1fv8xDE
    Jun 2008
    1082
    Re: SHARE YOUR SUB ROUTINES
    I have a calling program that makes use of GOTO commands, variables, "IF" conditions, and subroutines (separate subroutine files, but I imagine it would work with subroutines within the same file as well). The purpose of the program is to mill the same parts at many positions in a grid (it can also just do a line of parts and I'd guess it could be adapted for a rotary table).
    I posted the code and a pretty exhaustive explanation over here... (post #2)
    http://www.cnczone.com/forums/tormac...etter-way.html
    It didn't get much of any response over there so maybe it's not as good as I think it is. Maybe it's simply incompatible with Path Pilot (it does use GOTO, which apparently isn't supported by LinuxCNC). The GOTOs do make it a bit confusing, but the code is efficient as far as I can tell (as an untrained hobbyist).
    Since I don't have a Path Pilot machine I can't test my macro program with Path Pilot. I also don't use Mach3 any more, so I haven't tested it there either. That makes me wonder if I should be sharing it on this thread. On the other hand, I was introduced to variables by WOTDesigns, who shared some code he used with a Haas (I think). So I figured even my potentially incompatible code would be helpful.
    Aug 2010
    599
    I did a recent video on this:
    https://youtu.be/nh5Cn74naq8
    Sent from my SCH-I545 using Tapatalk
    warmachinellc.com
    Mar 2009
    1863
    I'm still using Mach 3 and after seeing that video, I don't think I'll be switching any time soon.
    When I run a sub routine in Mach 3, at the sub routine call the line says M98PXXXX.
    At the end of the sub, I tell it M99 and it goes back to the main body of the program.
    Then move to the next spot and M98PXXXX again then M99.
    Feb 2007
    1538
    Quote Originally Posted by SWATH View Post
    Thanks for that SWATH - The G code language you are using seems quite different from pathpilot.
    To save the time trialling, does anyone out there know if it would also work with pathpilot
    Keen
    Feb 2007
    1538
    Quote Originally Posted by Hirudin View Post
    Thanks for that HIRUDIN - Does anyone out there know if this code language would work in pathpilot?
    Keen
    Feb 2007
    1538
    Quote Originally Posted by Steve Seebold View Post
    Hi Steve. Yes you seem to be using the same code language as in the SWATH video above - does this language work in pathpilot?
    Keen
    Jul 2003
    1754
    m98/99 will be added to path pilot in the future... (they have already pushed it to a branch on linuxcnc.org for testing.) Thanks Tormach!
    Quote Originally Posted by keen View Post
    Keen
    Nov 2005
    201
    That is how i do it to
    Mar 2009
    1863
    Keen
    I don't know if the M98/99 code will work with Path Pilot. Tormach says they are working in it, but it's not available yet.
    I saw the 440 last weekend, and was quite impressed although, Andy was just babying the machine, it's quite capable of removing a lot of material if programmed the right way.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
  1. Simple routines for the offering
    By rfrenzl in forum G-Code Programing
    Last Post: 08-01-2008, 07:22 PM
  2. Help Making Sub Routines
    By PROTOTRAKFAN in forum Parametric Programing
    Last Post: 07-15-2008, 12:09 AM
  3. Sub Routines on VF3
    By Rocko1 in forum Haas Mills
    Last Post: 11-10-2007, 09:41 PM
  4. sub routines
    By earl in forum Fanuc
    Last Post: 03-04-2007, 09:34 AM
  5. ok share the knowledge share the wealth...huh...right
    By oaktree444 in forum MetalWork Discussion
    Last Post: 10-18-2005, 10:54 PM
