Hi, I am new to FeatureCAM and I need to use mill turn to mill a simple open ended slot across the front of a piece of 25mm dia bar. The slot needs to be 8mm wide and 20mm deep, so what kind of approach should I take regarding the kind of feature to select.
The machine is a Doosan Lynx 220 Y axis.
Also, The manual ISO code for this feature would be good.
Thanks.
