I have a Taig mill run by a Xylotex board and Mach3. I have been machining AR lowers and having pretty good success. Now when i am using Mach3 to jog the table in the X direction it starts out fast and after a couple of inches of travel slows down dramatically barely a crawl. It will do the same thing on the Y axis but not on the Z. Where should I look for the problem? Board? Steppers? wiring? thanks
