OK now I have read a lot posted by NC Cams on bearings, LEARNED a lot. ABEC 7 AC bearings are the stuff I get it now.
However, lets talk about tapered timken bearings, we touched briefly on them before and the problem with them was that when you get enough preload for them to be stiff they get hard to turn.
As to precision however......if you borrowed two of the tapered timken bearings used in a 1 ton truck rear end (new ones not used) and you set them up with the OEM preload.....for an application like an OD/ID grinder work head that runs at typically fairly low rpm, would they work ?? how "stiff" would they be compared to AC bearings ?? I know they would COST a lot less....but they seem to offer the benefit of handing radial and thrust loads both at he same time.
For the stated application the HP required to rotate them is not going to be an issue...most motors we would find secondhand will be BIGGER than what the job requires.
This is just a mental exerscise and should be treated as such :-)
Bill
