586,077 active members*
3,734 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > First build: Custom 24x24 based on CRP2448
    Nov 2015
    31
    Hello all, I am in the process of planning a build based on the CRP2448 manual, but with the long axis shortened to only 24 inches and I have a few questions.
    I am planning on using this mostly to do light production work cutting basic shapes out of phenolic plastic with fairly low precision needs, but would also like to be able to do some more precise work in other materials, especially aluminum for side projects.
    1. The 2448 plans use 60in extrusions for the long axis of the bed, this is 12in longer than the travel distance, does this ratio hold up for a shortened bed, i.e. I would need 36in bed rails?
    2. Can I use the Pro rack and pinion parts with the extended linear carriages, it looks like i could but I would hate to buy them only to find out otherwise.
    Jun 2004
    6618
    Re: First build: Custom 24x24 based on CRP2448
    I don't see why they would not work. You can study the available drawings to see what might be different. I find that the guys at CRP's (Ahren and Cory) answer questions quickly and always seem to have the right answer. No extra charge.
    To figure out the right lengths for everything, you would need to mock up each axis in CAD. Pretty easy since most of the necessary drawings are already available. You would be able to see rack lengths, extrusion lengths and actual machine footprint that way.
    Good luck with it and above all, have fun.
    Lee
    Feb 2004
    1086
    Hi Wildkard,
    You can scale things the way you mentioned if you want to go with a custom sized machine. There is some wiggle in the length of the gear rack you use -- this does not need to be precise. You just need the length of gear rack to be somewhere between the travel you need and the overall length of the axis.
    You can use the PRO rack and pinion parts with a standard machine kit, but you will need to add an additional part to the gantry to shift the larger pivot of the PRO R&P units -- otherwise they will interfere with the high z plate. We have these in stock, just shoot us a message through the website and we can work this up for you. Incidentally, we also have 36" pre-drilled steel we can sell you if you want to buy it from us.
    Best regards,
    Ahren
    CNCRouterParts
    Nov 2015
    31
    Thanks for the replies guys, should have a message from me soon.
  1. CRP2448 Build (My first CNC)
    By slisgrinder in forum DIY CNC Router Table Machines
    Last Post: 12-28-2015, 03:15 AM
  2. Indigo's 24x24 Momus build
    By st_indigo in forum Momus Design CNC plans
    Last Post: 04-25-2013, 04:08 PM
  3. Seitz333's CRP2448 Build
    By Seitz333 in forum CNC Wood Router Project Log
    Last Post: 12-13-2012, 03:18 AM
  4. CRP2448 Build Log
    By SD__ in forum CNC Wood Router Project Log
    Last Post: 06-16-2012, 05:53 PM
  5. CRP2448 build plan: is it rigid enough or is it just plain overkill?
    By kinghong1970 in forum DIY CNC Router Table Machines
    Last Post: 03-16-2012, 11:49 PM
