586,106 active members*
3,090 visitors online*
    Apr 2003
    95
    Chinese 6040 CNC Router
    Hello group, I am putting together a 6040 CNC Router from ebay and was wondering if I need to grease or oil the linear bearings that ride on the shafts? If so what do I use and what type of grease or oil? And how do I get the grease or oil in the bearings? Do I just put in on the shafts?
    Thanks for all the help!
    Eric
    Aug 2009
    655
    Re: Chinese 6040 CNC Router
    Either should work - unless the bearings are sealed and you are running on outer races- then just keep the rails clean. I'd just wipe down the rail with some grease or heavier gear oil and then run the bits over it unless you have a grease nipple or spot to pressure feed grease in.
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
  1. My Chinese 6040 Experience So Far
    By kronick in forum Chinese Machines
    Last Post: 05-12-2018, 11:48 AM
  2. Need Help with Chinese 4 axis cnc 6040 router.
    By urupeja in forum Machines running Mach Software
    Last Post: 12-16-2016, 10:43 PM
  3. 6040 CNC Router (Chinese)
    By ecope in forum Chinese Machines
    Last Post: 10-14-2014, 08:57 PM
  4. 6040 the S 80 Chinese router power problem?
    By jimmineycricket in forum Chinese Machines
    Last Post: 08-18-2014, 09:19 AM
  5. Chinese CNC Router (CNCDIY 6040 )
    By Domenicxx in forum Australia, New Zealand Club House
    Last Post: 10-23-2012, 09:08 AM
