586,332 active members*
4,402 visitors online*
    Nov 2009
    47
    Lightbulb ATC MACRO MACH3
    Hello all my name is Anna. I would like someone with experience in VB to write a MACH3 MACRO for me.
    I need my machine to perform the following sequence on tool change.
    step1 Z AXIS HOME
    step2 Z AXIS DOWN 100MM
    step3 ACTIVATE OUTPUT 3(PNEUMATIC PISTON PUSHING TOOL CHANGER CAROUSEL)
    step4 WAIT 1.5SECOND
    step5 ACTIVATE OUTPUT 4(DRAW CLAMP RELEASE)
    step6 Z AXIS HOME
    step7 SELECT DIFFERENT TOOL (AXIS A) 8 TOOL CHANGER
    step8 Z AXIS DOWN 100MM
    step9 DEACTIVATE OUTPUT 4(LOCK CLAMP)
    step10 DEACTIVATE OUTPUT 3(PNEUMATIC PISTON RELEAVED CAROUSEL HOME)
    END OF TOOL CHANGE.
    if anyone is willing to help or charge for the service please contact me.
    Best regards to all
    Anna
    Sep 2014
    16
    Re: ATC MACRO MACH3
    Quote Originally Posted by Machinaria View Post
    step1 Z AXIS HOME
    step6 Z AXIS HOME
    END OF TOOL CHANGE.
    Best regards to all
    Anna
    I am currently working on a 10 position Rotary ATC macro did you find what you were looking for?
    If not take a look and let me know if this is what your looking for?
    Be Safe,
    Sam
    https://www.youtube.com/watch?v=B9lHwb_JF3Q
    Jan 2014
    126
    Re: ATC MACRO MACH3
    Hi Anna, I have been programming a swing arm style ATC for a benchtop mill over the last 6 months. If you still need help, let me know and I can give you some tips. Its really not hard to work with once you get the hang of it.
    Feb 2006
    6
    Re: ATC MACRO MACH3
    step1 Z AXIS HOME
    step6 Z AXIS HOME
    END OF TOOL CHANGE.
    Best regards to all
    Anna
    Hi Anna
    did you get anywhere with this? Im also looking to sort out my ATC but I seem to be banging my head against the wall.
    Jason
  1. MACH3 AUTO TOOL ZERO MACRO
    By ZZRBlokey in forum Mach Wizards, Macros, & Addons
    Last Post: 04-12-2015, 06:57 PM
  2. Custom Macro for Mach3
    By visual14cnc in forum Mach Software (ArtSoft software)
    Last Post: 01-19-2015, 08:30 PM
  3. G32 macro or wizard for Mach3
    By Coolant Slinger in forum Mach Wizards, Macros, & Addons
    Last Post: 03-08-2013, 12:02 AM
  4. Costom mach3 macro for 12 pocket ATC
    By [email protected] in forum Mach Wizards, Macros, & Addons
    Last Post: 12-09-2012, 10:28 PM
  5. Macro Advice - Customising Mach3
    By UKRobotics in forum Mach Wizards, Macros, & Addons
    Last Post: 12-07-2012, 12:13 AM
