Need help setting a parameter, on yasnac i80 control, matsurra v510 , how do you enable parameter write? thanks
Press the RUN function key then press the SETTING soft key in the middle of the screen then press the SETTING soft key in the lower right corner of the screen. Now you should see PARAM CHANGE, press the WR key to change it. Be sure to turn it back off as it will cause a cycle start interlock.
That's what I needed to know, Gotta love the zone! thanks Mike283
