Hi Forum,
I have successfully wired my home and limit switches to my G540 running Mach3 under windows... All good and happy here. However I have setup a probe and cannot seem to get it working, here is the scenario
Enabled Probe in Mach 3 - Active low
Probe connected to G540 via 4 and 12 (common)
Check continuity with multimeter for wiring up to the G540 board - works as expected in a NO configuration.
on Auto-set under mach 3 could not get the damn thing to work
Checked in diagnostics no inputs light up when probe is connected
So I opened the G540 box, set mach3 to auto set for probe on active low, then use a straight wire between G540 connecter 4 and connector 12 to simulate a probe eliminating any wiring issue outside the box. - Still no joy ........WTF
any guides here?
