I have just bought an Omni 1325 , the machine has the y axis as the long axis and the x axis is the short one, the problem I have is that I want to cut plywood sheets from dxf files supplied from a designer, and I use cut 2d to process them and mach 3 to run the machine. The machine came with mach 3 installed so it seem to see the work table as y being 2500mm long and x being 1250mm. Can anyone recommend an easy way to fix this, either by changing the axes in cut 2d or in mach 3.
Or would it be easier to use a different software package where I can re assign the axes.
Needless to say I am a bit of a newbie at this so any advice gratefully received.
Tony
