586,068 active members*
3,765 visitors online*
Results 1 to 9 of 9
    Apr 2013
    1788
    PP 1.9.3 released
    PathPilot v1.9.3 is now available for download from Tormach.com
    In this version:
    • Canned Cycles bug fix
    • Mill - Probing bug fix
    • Mill - Door switch bug fix
    • Lathe - G59.x bug fix
    • Mill/Lathe - G code interpreter enhancement
    • Mill - Conversation enhancements and bug fixes
    • Mill - Error Message bug fix
    • Mill/Lathe - File Chooser bug fix
    Enhancements -
    • Mill/Lathe - G code interpreter: Add M98/M99 support to PathPilot
    • Mill - G code interpreter: Support for G52 temp coordinate offsets
    Feb 2007
    1538
    Re: PP 1.9.3 released
    Quote Originally Posted by kstrauss View Post
    In this version:
    Enhancements -
    Yes great news! Please test it completely to expose any new bugs and let us know all is well ASAP.
    Many thanks...Keen
    Jun 2005
    656
    Getting a "not valid g code file format" error on some files that loaded fine in 1.7 when last tested.
    Edit: tried 1.9.2. Same issue. Probably not 1.9.3 issue then
    Updated: talked to Tormach, they are doing more file validation since 1.7.2 and some goofy text in my code-comments causes it to reject the file.
    So, not a 1.9.3 issue. 1.9.3 testing continues apace.
    Sep 2009
    624
    Quote Originally Posted by shred View Post
    There was a comment in an earlier thread about file names and engraving fonts which gave PP fits. Sounds similar.
    What "goofy text" is causing a problem (if you can share)? Easier to know and avoid than find it myself (I'm a fanatic commenter, a habit left over from the days when programs were recursive, re-entrant, self-modifying and written in assembler).
    Dec 2006
    302
    I'll give it try because I really miss M98/99. Those are handy for guys who manually code.
    Entropy Sucks
    Nov 2007
    2151
    Quote Originally Posted by GLCarlson View Post
    You forgot to mention tsr or terminate and stay resident in that list.
    Those are called viruses now.
    Anyway, I make my cam program generate all code and only review for function. I find few problems with path pilot and already made a hand full of parts with 1.9.3 first thing this morning.
    Jun 2005
    656
    In this case, double-slashes contained within the first few lines of comments accidentally triggered the bad-code filter, which Tormach fixed within the hour after we zeroed in on the cause. After 5pm WI time too. That change will probably be included in the next official upgdate after a bit more testing.
    Sep 2009
    624
    Thanks. Multiple slashes (and at signs/pound signs) are among the things I learned to use inside comments to find specific things like dates or authors quickly. EG ###(date). Tormach continues to impress.
    Jun 2014
    1780
    I had an anomaly in v 1.9.3 yesterday, it went into some kind of loop in the program on the main section of the screen, it wasnt running, I had stopped the program, hit reset and run, then it went into some sort of loop. The program ran fine after a shutdown and restart.
    I will add that it did run the part correctly, I have not had PP do anything that it wasnt supposed to do while machining!!!
    mike sr
  1. Looks like 2.5 has been released!
    By wizard in forum LinuxCNC (formerly EMC2)
    Last Post: 04-05-2012, 11:56 AM
  2. 4.3 released
    By svenakela in forum MadCAM
    Last Post: 01-02-2012, 07:39 PM
  3. emc 2.2.6 released
    By samco in forum LinuxCNC (formerly EMC2)
    Last Post: 08-21-2008, 04:13 PM
  4. EMC 2.2.4 released
    Last Post: 03-18-2008, 05:57 PM
  5. When Does X Get Released?
    By CAMCRASH in forum Mastercam
    Last Post: 04-21-2005, 08:23 AM
