586,106 active members*
3,012 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam X9 4th axis problem
    Nov 2015
    Question Mastercam X9 4th axis problem
    Hello for everyone,
    I have a probelm using mastercam x9 with 4th axis... The problem is that I have cut asymmetric part, and when I generate a toolpath bit cuts off one small part out of the whole part.. It will be simple if mastercam also use Z axis to control the height of the bit, but it don't.. In order to better understand what I can't do, I'm adding mastercam file and some photos.
    Thanks, Edgaras.
    Apr 2003
    3578
    Re: Mastercam X9 4th axis problem
    Change the Axis Dampening Length to 30. this will fix it.
    Cadcam
    Sep 2011
    43
    Try using "use center point".
    John
    Apr 2003
    3578
    JCSB, did you notice doing that the the shape you are showing is not correct. As I saw he did not check that option. But based on the shape and the orientation of the part this would not let it complete the undercut at the top.
    Cadcam
    Sep 2011
    43
    I see what your talking about and no I didn't. I must admit that I did it very quickly without noticing that. I just saw that it appeared to be similar but see under closer review it isn't.
    John3
  1. Mastercam Rotary tool path A axis problem
    By Fr0ssT in forum Mastercam
    Last Post: 06-16-2015, 07:45 AM
  2. Mastercam rotary axis problem
    By squirrel_41 in forum Mastercam
    Last Post: 06-29-2012, 06:47 PM
  3. Mastercam rotary axis problem
    Last Post: 06-02-2012, 02:26 PM
  4. Mastercam 5 axis router post repositioning problem
    By reinhartdr in forum Post Processors for MC
    Last Post: 06-09-2011, 04:27 PM
  5. Mastercam x c-axis problem
    By Mike68 in forum Mastercam
    Last Post: 11-20-2008, 02:21 PM
