586,075 active members*
3,967 visitors online*
    Apr 2015
    19
    homing troubles
    Hello,
    I built a 3 axis machine the uses a slave drive on my x axis. Everything runs and works great other then homing.
    When homing my x axis, everything is fine until the axis hits the limit switches. Once the switches are activated both the slave and master motors want to go the the opposite direction.
    I have a normally open proximity switch on my slave side and a normally closed on my master side.
    I have tried changing both my Active Low settings and Home Neg settings.
    The only thing i can think is that maybe my Slave axis is wired backwards.< i am not sure if it is or not, but i do have my slave axis uncheck for Dir Low Active.
    hope someone can help,
    Mike
    I
    Apr 2014
    432
    Re: homing troubles
    I thought I saw it as ,If you slave one axis to another effectively you are trying to run them both at once? that's of course if I have written it the rite way round so I have the boxes ticked none.
    Apr 2015
    19
    Re: homing troubles
    I needed to wire my slave drive backwards so that they are both not ticked.
    But that did not fix my problem. when I run my ref all home and my x axis goes to the homing switches things get all weird on me. the slave keep going into the switch and the x goes away.
    Apr 2015
    19
    Re: homing troubles
    mannnnnnnnnnn i feel dumb.. i had to my slave and master drive cords plugged in backwards going into my geckodrives...
    how do you delete a thread?
  1. Replies: 13
    Last Post: 06-25-2014, 02:21 PM
  2. X3 troubles
    By binfordw in forum Benchtop Machines
    Last Post: 09-06-2010, 02:29 PM
  3. MAX 100 troubles
    By matttargett4 in forum Hypertherm Plasma
    Last Post: 04-01-2010, 08:25 PM
  4. RPM troubles...
    By rylanrouge in forum MetalWork Discussion
    Last Post: 03-02-2010, 07:44 PM
  5. air troubles
    By wadetool in forum Haas Mills
    Last Post: 02-19-2007, 10:30 PM
