586,075 active members*
4,298 visitors online*
    Apr 2015
    19
    Another homing issue.
    When trying to home my machine, the a axis bounces off the sensor twice. i assume it is still squaring my machine right, but i don't like the double bounce, and that seems like it should not happen.
    Also, i am about to put my bumpers on. when you auto square the machine do you want to put the bumpers exactly where the machine hits the homing limits?
    Thanks for the help, here is a video of the problem in action. https://youtu.be/0rT3xZUT-OU
    Mike
    Re: Another homing issue.
    You probably need to edit your homing script. The default script homes the A axis last, which may be what you're seeing.
    Apr 2015
    19
    I think you are right, thanks for the quick response.
    found the solution.
    Homing Problem - Slave Axis
  1. Homing Issue on one axis
    By Abereux in forum Mach Mill
    Last Post: 10-19-2015, 06:49 PM
  2. MH-400 ATC Homing issue
    By mikenboys in forum Maintenance DIY Discussion
    Last Post: 06-04-2014, 04:45 PM
  3. 0-M Start up homing issue
    By hrhoward in forum Fanuc
    Last Post: 02-08-2013, 01:35 AM
  4. Mach 3 homing issue.
    By evo4wrx in forum CNC Machine Related Electronics
    Last Post: 07-10-2010, 03:04 PM
  5. Homing Issue
    By Moondog in forum Machines running Mach Software
    Last Post: 07-30-2006, 04:23 AM
