586,069 active members*
3,484 visitors online*
    Unhappy Alarm 28 X Print Circuit Board Malfunction
    Hi;
    I have a 1990 Mazatrol M 32 VQC 15/40.
    About two months ago I have replaced the Disk floppy unit drive, by an USB Mitsubishi simulator, and the famous battery.
    There was no problem at all, but past week, when I tried to do machine home,immediately appears the alarm #28 X Print Circuit Board Malfunction, and in the X servo amplifier appears #17.
    So i have decided to clean all the card and tight all the earth screws.
    Then the machine starts, but this time during homing appeared alarm #37 X Over Ampere and in the X servo amplifier appears #32.
    I turned it off again, waited some minutes and again I tried to turn it on, but this time again alarm # 28 X Print Circuit Board Malfunction,and in the X servo amplifier appears #17.
    Sometimes tha machine turns on, but the alarm appears during X axis homing, and then turns it off.
    I want to swap drivers, can someone explain me the procedure?
    Thank you in advance.
    Apr 2007
    13
    Re: Alarm 28 X Print Circuit Board Malfunction
    Alarm 17 means encoder problem,just change it
  1. Alarm 221 (Turret Sensor Malfunction)
    By motif in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-15-2022, 01:21 PM
  2. Replies: 1
    Last Post: 06-26-2015, 01:55 AM
  3. Print plastic traces on nlank copper clad for circuit board etch resist
    By DrStein99 in forum 3D Printer / 3D Scanner Discussion
    Last Post: 05-28-2014, 04:34 PM
  4. T32-3 System Malfunction Alarm 015 (2,9476)
    By Ben Colby in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-18-2012, 03:04 PM
  5. Mazak T32-3 Alarm 015 System Malfunction
    By reillyeng in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-27-2011, 02:24 PM
