hello
i am new to laser machine i used to use a plasma machine ... now i tried to switch to laser .. i recently bought laser engraving machine MCP6515 and with it came a Laser Cut 5.3 CD and two flashes one is a softdog and the other is a normal flash .... what my problem is i tried to export a file using laser cut 5.3 to the machine by using flash ... the machine reads the file .. but when i try to start it an error message pops out on the PAD03 screen saying that my dll version is different from the firmware .... i tried to update the firmware of the machine using these info :-
Laser Engraver / Cutter Machines
(p.s. i used flash to convert the firmware files to the machine)
i did what the instruction said but nothing happened
i don't know if this helps but my MCP6515 version is 4.0.3 and the laser cut 5.3 is 4.1.3.0
i would be grateful if you help as soon as possible
thanks in advance.
