586,058 active members*
3,602 visitors online*
    Feb 2010
    4
    extra circular movement in mach3
    Hi, Why i see extra circular movement in mach3 ?!
    it's correct in Solidcam
    Attachment 297046
    But in Mach3:
    Attachment 297048
    Thanks in advance.
    Re: extra circular movement in mach3
    Change your IJ mode in Mach3.
    May 2015
    1422
    Usually from absolute to incremental on I,J (or vice versa) in the config screen.
    Or change your SolidCam post to send it differently, whichever is easiest.
    15362
    sarsali
    The same as what Gerry has said, this is where to change it, open the General Configuration File you want it to look like this photo, this then should match your G-code program
    Mactec54
    Feb 2010
    4
    Thanks dear ger21, dharmic and mactec54 for your responses
    but by that config you mentioned, why route of tools(green line) and route of mach3(violet line) are different ?!
  1. No movement with Mach3, C10, 4030
    By tsumara in forum Mach Software (ArtSoft software)
    Last Post: 02-20-2014, 04:01 AM
  2. No motor movement using mach3 and g540
    By dougncin in forum Gecko Drives
    Last Post: 12-24-2013, 02:45 AM
  3. Mach3 Help with axis movement
    By CEStanley in forum Mach Software (ArtSoft software)
    Last Post: 10-13-2012, 04:32 AM
  4. mach3 loaded no movement
    By fusiontech357 in forum Mach Software (ArtSoft software)
    Last Post: 11-19-2009, 06:27 AM
  5. SX3 - Mach3 - non standard pin config - no movement...
    By krazatchu in forum Mach Software (ArtSoft software)
    Last Post: 11-24-2007, 05:45 AM
