I have a 4 axis TB6560 (blue) control card and an inductive proximity sensor which I need to connect to the control card and read trough Mach3. I really am not good with electronics so I need help on this.
I believe I can't connect the 3 wires from the sensor directly somewhere on the card, I can power up the sensor from an external power supply however. So what about the signal wire of the sensor?
The sensor I have is CARLO GAVAZZI ICB12SF04PO SENSOR, INDUCTIVE, 4MM, PNP-NO, 10-36VDC
Any help would be appreciated.
Best,
Suat
