I just finished building my DIY router and got the electronics hooked up and working through PP & Mach3. I wanted to add limit, homing, and estop switches to my BOB (stv2) but I'm having some issues with the wiring.
Attachment 297390
To setup my estop, I ran a wire from GND & P10 to a switch and tried the "signal diagnostics" in Mach3 but got nothing... I also tried PSU to GND (on BOB) and to P10 and still nothing. I read somewhere that you need to run the "optional" 12-24V (on right side in pic) to this specific BOB to get everything working but I'm not sure and don't want to burn it up (already running 5V from USB). Is it true that both red LEDs have to be on for this to work properly as I only have one. Lastly, if the 12-24V is needed, can I just run an extra wire from the PSU or do I need a different power supply (somewhat worried about amps being too high).
Thanks for your help!
FYI,
BOB: stv2
Drivers: M542 drivers
PSU: 350W 36V 9.7A
