586,847 active members*
2,166 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0M KIA VA-40 Spindle Orient issue
    Aug 2013
    4
    We have been having spindle orientation issues.
    The issue is during a tool change the spindle will orient but then the machine will sit there. Sometimes this happens......sometime the machine tool changes fine with no issues.
    I thought that the input from the spindle amplifier was faulty but found the input in the ladder and all is fine there. So I kept searching to see what was hanging up. I found that F150.0 is not resetting all of the time after the spindle orientation is complete. I'm assuming that this is the m code for spindle orientation? the manual that I have does not give much info other then the saying "m-code". Is this possible and if so what can this?
    Thanks for anyhelp
    Jun 2004
    511
    Re: Fanuc 0M KIA VA-40 Spindle Orient issue
    F = Flag That is normally an internal thing. Call Fanuc, they will help you.
  1. Conquest 42 Fanuc OT control, Spindle Orient
    By edeaton in forum Hardinge Lathes
    Last Post: 12-31-2015, 07:44 PM
  2. Spindle Orient Speed Fanuc 15MB
    By jdandersonjr in forum Fanuc
    Last Post: 04-10-2014, 04:37 PM
  3. spindle orient fanuc 15 series
    By tleck in forum Fanuc
    Last Post: 02-18-2011, 03:03 PM
  4. Replies: 2
    Last Post: 12-28-2008, 07:35 PM
  5. Replies: 2
    Last Post: 01-24-2007, 06:56 PM
