Ok so its new to me. I brought a barely used baron mill from the original owner who quite frankly had no clue on machining. Having been used twice in its life it has sat till now.
I contacted cnc masters to ask questions and was immediately told since I was not the original owner I would have to pay 595 bucks for any technical or trouble shooting support...... 595 bucks for advice, help or what???
Or I could buy a whole new updated controller for 2600....with life time support for as long as I own it...
Now I looked and looked but no where can I find any support using this software. My machine was built in 09 so I believe there has been 2 or 3 different controllers built. Now I find it funny that even the newest version still barely does what mach3 will do. So I figured before I pay for support or tech advice for a system only they seem to know.... I will ask for help here?
Now I want you guys to know I am not a computer guy nor do I know anything about build a cnc. But I can use mach3 and I do own a full license mach3 with wizards. So I do have that. I owned a dyna myte cnc mill before and I ran it on mach3. I am hoping I can find someone in Pennsylvania who will assist me or if I can find someone who can build me a plug and play system? That would be great. And yes I would pay you for your skills.
I want to keep my
Dual shaft 34 neme 1200oz motors
Use my vfd to control my spindle with mach3
Use my limit switches that are installed
Use a handheld remote
The machine is a rf45 clone btw. It is stepup with ballscrews in x and y. The z is the acme screw and its using the quill. I would one day love to power the z with a ball screw on the column. I would even love to have a ballscrew on the quill instead. So if you can help with that if possible??? I do have a hand held remote now but I am unsure if it will work with the new system. At the present time the machine is using a USB and not a parallel port. And I have a dell laptop running windows xp pro. I have not yet used the system because I am currently building a work bench that will wind up being a full enclosure with flood coolant. Plus I need to run my single phase 220. Which should be done this weekend. I am going to setup everything to run it because I brought it without seeing it run but seeing the conditions of the mill and how the gentleman who sold it to me keeps his shop (dead on spotless!)
I feel it will be fine. If not I know I couldn't have built the machine into a cnc mill minus the electronics for what I paid. so I cant get upset since I want to run mach3 anyway.right?
So I have posted twice in this forum asking for help. Now I am trying here. Please can someone help me or something? Anyother cnc masters baron owners here? I would also like to mention that i have a jet mill (bridgeport clone) and a Ramco prince 12x36 lathe (which i want to turn into a cnc). And i do have some experience with machining. I am also willing to let who ever helps me have the cnc baron controller and software once I am running on mach3....just throwing it out there. Thanks
