If you have any expectation of doing aluminum well, a lube or coolant will be required, as such that rules out and machines with work in their designs.
No pointers to plans.
One thing I would point out is that you need to either buy a kit or enlist the help of a local machine shop or fabricator is you don't have a lot of tooling on hand. The best savings come from being able to fabricate much of a machine yourself. The fabrication isn't difficult if you have some experience but can be frustrating if your skill set and tooling situation don't allow for good results. A fabricator does add to the cost though so that is something to consider.
A second thing here, The greater the importance that you place on the aluminum end of the machinable spectrum the more robust you should build this machine. At some point the kits I know about simply won't do as they are not robust enough for a machine primarily focused on aluminum. If you only expect to attack aluminum once in a great while then the story here is a bit different but too loose of a machine can be a huge issue even for minor one off projects. It comes back to expectations.
