Hello fellow programmers, im trying to get surfcam 2004 to post the same rotary moves that it makes in
the predator software. the axis moves seem to have the right numbers its just missing the the - sign.
would like to use the mpost.
thanks!
thanks!
Add
RevSigns A
to the "command and switches" section of your post.
ok thanks! I will give it a try.
so write those exact words in my mpost? where would I write them? im a mpost newbie.
thanks
This should give you a general idea where.
Attachment 298866
Make sure your A address is formatted like
It may need to be A ->5.>3
The numbers just control how many digits can come before and after the decimal.
Search your C: drive for "MPost Getting Started.doc" and "MPost Format Reference Manual.doc" if you want to know more about it.
I'd give you the path to them but I'm not sure what it is for a version that old.
